Breathe safer and easier
Air Sentry disposable, contamination-control breather is used in any reservoir containing fluids or semisolids. Air is forced through a 2-micron solid particle filter; water vapor is removed through a bed of silica gel.
Air Sentry disposable, contamination-control breather is used in any reservoir containing fluids or semisolids. Air is forced through a 2-micron solid particle filter; water vapor is removed through a bed of silica gel. Another 2-micron filter provides clean, dry air. An indicator warns when the breather should be replaced. National-Spencer, Inc.
Circle 252
