Bolted pump
E3 bolted pump handles 3/4-in. solids and features ANSI/DIN flange inlet and discharge manifolds. The manifolds have a cast-in boss on each side for draining purposes.Versa-Matic Pump. Co.
E3 bolted pump handles 3/4-in. solids and features ANSI/DIN flange inlet and discharge manifolds. The manifolds have a cast-in boss on each side for draining purposes. Versa-Matic Pump. Co. www.versamatic.com Booth 8936
