Blowers resist corrosive fumes
All-polypropylene blowers, in capacities from 300-85,000 cfm, are available in belt and direct variable frequency drive configurations.
All-polypropylene blowers, in capacities from 300-85,000 cfm, are available in belt and direct variable frequency drive configurations. These blowers are suited for use with HVAC equipment, air scrubbers and incinerators, and chemical processing equipment; and can replace conventional blowers that have deteriorated through exposure to acid fumes or corrosives. They are prewired and easily retrofit into a wide range of equipment. The operating temperature limit is 180 F.
Tri-Mer Corp.
www.tri-mer.com
Circle 372
