Belt-type oil skimmer
The Mini-Skimmer R.S. is a belt-type oil skimmer designed to collect over a quart of oil p/hr, skim unwanted tramp oils from coolants, and clean wastewater.
The Mini-Skimmer R.S. is a belt-type oil skimmer designed to collect over a quart of oil p/hr despite its tiny housing that measures just 3"x 3" x2.75". It also is designed to skim unwanted tramp oils from coolants and clean wastewater. The oil skimmer has an on/off switch to allow users to easily monitor its activity for machine shops, ultrasonic cleaners, and parts washers. The skimmer for small machining operations is portable with a stretch-resistant, fiberglass-reinforced cogged belt. It has a liquid tight housing made of anodized aluminum and a motor with the highest torque for a skimmer of its size.
