Ball valve jacket prevents blockage
Jacketed sanitary ball valve controls product flow through inline and outlet valves, and prevents solidification and blockages with efficient valve jacketing for use with hot water, steam, and other heating or cooling mediums.
Jacketed sanitary ball valve controls product flow through inline and outlet valves, and prevents solidification and blockages with efficient valve jacketing for use with hot water, steam, and other heating or cooling mediums. Jacketed, flush-bottom, two-way, and multi-port divert valves are available in sizes from 1 1/2 – 4 in., and are designed for corrosion-resistant, highly sanitary applications. They are USDA approved, and meet 3A specifications.
Lee Industries, Inc., Fluid Transfer Div.
www.LEEind.com
Circle 373
