Automatic pressure calibrator series
The 729 series automatic pressure calibrator simplifies the calibration process by automatically generating precise test pressures.
By Fluke Corporation June 14, 2017
The 729 series automatic pressure calibrator simplifies the calibration process by automatically generating precise test pressures, improving calibration integrity by compensating for leaks, and automatically documenting the pressure calibration process to help meet compliance and regulatory requirements. With the rugged, portable 729, technicians simply input a target pressure and the calibrator automatically pumps to the desired set-point while the internal fine adjustment control stabilizes the pressure at the requested value, delivering more accurate results and speeding the calibration process. It also features automatic pressure generation and control for multiple tests to 300 psi and measurement of mA signals on transmitter outputs and sourcing and simulation of mA signals.
Fluke Corporation
www.fluke.com
