Attenuator relays
A152 relays are suitable for attenuating RF signals in 50-ohm systems over a frequency range from dc to 5 GHz. The relays are hermetically sealed against inclement weather and extreme environments. The relays feature high isolation between the signal path and the control voltage, low insertion loss of relay contacts and a large bandwidth.
A152 relays are suitable for attenuating RF signals in 50-ohm systems over a frequency range from dc to 5 GHz. The relays are hermetically sealed against inclement weather and extreme environments. The relays feature high isolation between the signal path and the control voltage, low insertion loss of relay contacts and a large bandwidth. The relays offer a stable attenuated value over a range of frequencies and temperatures, eliminating the need for external resistors and attenuators.
Onlinecomponents.com
www.onlinecomponents.com
