Application modernization: HP promises a clear path for legacy system upgrades
Hewlett-Packard says it now has a way of letting companies literally see the right path to take when it comes to updating legacy systems. If the methodology works as advertised, it could spur a cycle of companies super charging aging applications that still perform critical business functions albeit at less than optimum speeds.
05/20/2008
Paul Evans, HP’s worldwide director of application modernization services, says when HP recently surveyed European business executives, 94 percent said it was important to have a strategy for keeping business applications up to date, but only 19 percent said their companies actually had such a strategy in place.
Evans says companies tend to avoid updating legacy systems because many of those systems perform functions that provide a competitive edge, and up to now the only real option for upgrading these systems has been to replace them, and that typically leads to a loss of that critical functionality. Instead, companies have retained these systems—many of which still run on mainframes—and absorb huge maintenance costs as the systems continue to age.
“Companies are spending up to 70 percent of their IT budgets to maintain legacy systems—as
This is a big problem for manufacturers, who according Evans, are the second largest users of mainframe systems, trailing only the financial services industry.
Recently, Evan says, HP has sensed a growing frustration among its customer base about the performance of legacy systems, and that prompted development of a set of tools and services for transforming legacy applications.
These capabilities, unveiled this spring, include:
Evans says these offerings will help companies modernize legacy systems more quickly and cost-effectively with less risk.
The HP Modernization Factory is a group of HP consultants with expertise in modernizing legacy systems who can be dispatched anywhere in the world as needed. The HP Modernization Showcase Centers will be established in strategic locations around the world, allowing customers to come in and see demonstrations of how various modernization strategies would work in their businesses.
The tools for analyzing legacy system performance are:
Evans says these tools allow users to get a graphical view of which applications should be replaced, retired, or re-engineered in order to improve their overall value to the business. This picture emerges through a series of color-coded graphs and charts pointing out how applications currently are performing.
Evans likens using this system to taking an X-Ray to diagnose a broken bone. “Before X-Rays, doctors would feel your arm and say it was broken. Now, they show you the picture, you see where the break is, and they can tell you how to fix it.”
Evans says HP saved a U.S-based logistics provider $1 million by using these tools to show that adding more processing power to its existing mainframe was not the best approach for modernizing one of its critical applications.
Response times for this application, which tracks the movement goods through the company’s delivery network, had become increasingly slower over time. The mainframe’s vendor had suggested adding more processing power, at the cost of $2.5 million, according to Evans.
During its analysis, HP found that much of the mainframe’s processing power was devoted to the ETL (extract, transform, and load) function. ETL is a method of putting data that originates in various formats into a single format that allows for it all to be processed by the same application.
Over time, the number of number of formats in which this company was receiving data has grown significantly, and that was hampering the performance of its critical business application.
“We could have made [the business application] go faster by adding more power to the mainframe,” Evans says. “But there are now special programs on the market that do nothing buy ETL. So, we recommended that they lift that function off of the mainframe, and put it on a separate system. They could then move the normalized data to the mainframe as it was needed.”
The total cost for this option, according to Evans: $1 million. “We also gave them a future proof solution,” he adds. “They moved the ETL program to an HP Integrity server that can be replaced when necessary, at a cost of $100,000 or less, rather the $1 million plus it would take to replace a mainframe.”
