Analog output encoders
Hollow- and solid-shaft high resolution analog output encoders provide 12-bit resolution with a choice of analog output.
The ENA361M hollow-shaft and ESA361M solid-shaft series high resolution analog output encoders provide 12-bit resolution with a choice of analog output. Designed for high reliability and high precision industrial automation and process control applications, the units have greater than 500-gram shock and greater than 30-gram vibration resistances. The series has a temperature range of -40 to 85 C and the standard units are IP67 sealed. The single-turn encoders offer a choice of 4-20 mA or 0-10 V outputs, and feature measuring range options of 45, 90, 180 or 360 degrees.
Micronor
