Air-operated diaphragm pumps for explosive atmospheres
MID and CU15 air-operated diaphragm pumps are designed to facilitate transfer of liquids up to 5000 cps in explosive atmospheres.
By Clark Solutions October 7, 2015
The MID and CU15 are miniature air-operated diaphragm pumps facilitate the transfer of liquids up to 5000 cps in explosive atmospheres and petrochemical industries. These pumps feature a stall-prevention pneumatic system design that does not require lubricated air, allowing dry operations without incurring damage. The MID pumps provide flow rates to 5 LPM at pressures to 70 meters and a maximum operating temperature of 60 C. The CU15 pumps provides flow rates to 17 LPM at pressures up to 70 m. For polypropylene models maximum operating temperature is 60 C and for ECTFE models it is 95 C.
Clark Solutions
www.clarksol.com
