Air knives that resist temperature and corrosion
Air knives that can withstand temperatures up to 800 F and are ideal for blowing corrosive chemical off parts, drying food products, and cooling hot materials such as molten glass, casting, and molded parts.
The air knives shown have a corrosion resistant design that ensures seamless airflow with a maximum length of 2743 mm and are designed to withstand temperatures up to 800 F. The design minimizes compressed air and is ideal for blowing corrosive chemicals off parts, drying food products and cooling hot materials such as molten glass, castings and molded parts. The knives are maintenance free and has a compact profile with compressed air inlets located on each end and the bottom to permit easy mounting in tight spaces.
Exair Corporation
