Air filtration module
Featuring a taper fit closure, the 2nd generation MediaPAK module offers a quick-connect, positive mechanical seal.
Featuring a taper fit closure, the 2nd generation MediaPAK module offers a quick-connect, positive mechanical seal. The
module is designed to ensure precision in airstreams and provide validated filtration efficiency. It also features Posi-Track technology, an angled notch in the module’s frame that fits onto a corresponding angled frame to create a positive seal. It can be used in both vertical and horizontal airflow systems and is suitable for commercial and industrial applications where adequate indoor air quality is required.
Purafil
www.purafil.com
