Adjustable LED lamp
The Lotus Lamp is designed for versatility with a 180° adjustable mounting arm that allows the Lamp to install in multiple positions and at different lengths for use in a wide variety of applications.
The Lotus Lamp is designed for versatility with a 180° adjustable mounting arm that allows the Lamp to install in multiple positions and at different lengths for use in a wide variety of applications. The lamp is designed for use with cecessed cans, canopy lights, parking garage fixtures, parking lot lights, flood/spot lights, high ceilings, and high / low bays. The LED Lotus replaces anything up to 400W metal halide and high pressure sodium lamps with up to 80% energy savings. The Lotus has 60,000 hours of rated life and comes with a 20kA In-line surge protection device to protect the lamp against disruptive and damaging power surges and transients. The Lotus is completely protected from contact, dust, and water splashes. Waterproof quick-connectors also makes the Lotus ideal for temporary lighting.
HyLite
