Absolute, inductive rotary encoder
ECI 119 Absolute Rotary Encoder features a low profile, 524288 positions per revolution, ±90” system accuracy.
02/07/2011
Heidenhain releases an absolute, inductive rotary encoder. Called the ECI 119 Absolute Rotary Encoder, this encoder sets itself apart with a low profile (height of 19 mm, outside diameter 92 mm) and large through shaft (50, 38, or 30 mm), making it suited for electric motors in many applications, including general automation, electronics and packaging industry, robotics, plastic injection molding machines, as well as on swivel and tilting axes. HEIDENHAIN ECI119
Expanding on the established ExI 13xx and ExI 11xx series, the Heidenhain ECI 119 is a singleturn, absolute encoder offering 524288 (19 bit) positions per revolution, and provides ±90” system accuracy.
The ECI 119 uses HEIDENHAIN’s EnDat serial data interface. Two types of output are offered: purely serial data (EnDat21) or serial data with 1 Vpp incremental signals (EnDat 01). The SSI interface can also be implemented, but this requires a minimum value order. Not only does EnDat allow the user to transfer incremental and absolute position data, it also enables online diagnostics.
An up to date version of the Adjusting and Testing Software is available with the ECI 119. This software allows diagnostic checks of the encoder position signals. And the new ExI Mounting Wizard allows the scanning gap and signal amplitude to be checked in order to assess mounting quality.
www.heidenhain.us
HEIDENHAIN
- Edited by Gust Gianos, CFE Media, Control Engineering, www.controleng.com
