2008 New Product Compendium: Process Instrumentation and Control Components
The following products were introduced in 2008, and participated in the Control Engineering Engineers' Choice Awards competition.
02/10/2009
Descriptions were provided by vendor companies. For more information, visit the Website listed. To learn which products won the competition, and which received honorable mentions, visit www.controleng.com/awards . To jump to a specific category of products, click on the following links.
  • Flowmeters
  • Process sensors
Flowmeters
Micro Motion 2-wire Coriolis flow and density meter
Emerson Process Management, Micro Motion Division
Emerson’s Micro Motion 2-wire Coriolis meter with MVD Technology extends highly accurate mass flow and density measurement to loop-powered applications eliminating the need for additional power wiring.
Bringing forth the same quality, robust features of Micro Motion Coriolis, the new two-wire meter delivers measurement accuracy, repeatability and operational savings on a level not previously possible for flow loops with older flow measurement technologies. The new meter delivers +0.10% liquid flow and +0.0005 g/cm3 liquid density accuracy in continuous process and mass balance applications. It has no moving parts and requires no maintenance. The two-wire Micro Motion 2200S transmitter can be used with a range of Micro Motion Elite Coriolis sensor sizes and materials of construction to deliver excellent measurement performance for continuous process applications. Suitable for integral or extended mount, the innovative loop powered design makes for seamless integration into existing control systems and is ideal for long wiring runs and applications in hazardous areas.
Equipped with MVD digital processing technology, the Micro Motion 2200S transmitter delivers multivariable and diagnostic information via HART communications for reduced costs through improved process consistency and maximized uptime. Front-end digital processing dramatically reduces signal noise and delivers a faster response time compared to analog devices. Micro Motion two-wire Coriolis is ideally suited for use in the chemical, petrochemical and refining industries, and for continuous process and mass balance applications.
Link to Product Data Sheet for the Emerson’s Micro Motion 2-wire Coriolis meter .
www.micromotion.com
ST51 Flow Meter for BioGas, Digester Gas, Methane & Natural Gas
Fluid Components International
The ST51 Mass Flow Meter provides highly accurate and reliable gas flow measurement in green energy applications in the emerging methane-to-markets processes that reduce greenhouse gas emissions and use biogas in the co-generation of electric power
The ST51 Mass Flow Meter is designed to solve the unique challenges to gas flow measurement in bioprocess generated methane, which reduces greenhouse gas emissions and uses the biogas in the co-generation of green, renewable electric power. The ST51 features a no-moving parts design that’s non-clogging and operates over a wide flow range with low-flow sensitivity. It’s packaged in an explosion-proof transmitter, and the calibration is matched to the user’s actual gas composition and installation conditions. In anaerobic digester produced biogas, gas flow measurement is challenged by the wet, dirty, toxic and potentially explosive nature of biogas. The wetness, H2S and other particulates in the gas create a corrosive condensate that deposits itself on the pipe wall and instruments in the pipe. The ST51 features a thermal mass, insertion-style flow element with flow accuracy to(-18 to 121°C) and withstands pressures up to 500 psig [34 bar (g)].
www.fluidcomponents.com
SM Magnetic Inductive Flow Meter
ifm efector inc.
The ifm SM Series magnetic inductive flow meter mounts in-line to detect the flow rate of conductive media up to six gallons per minute.
ifm’s SM Series magnetic inductive flow meter is designed to reliably detect the flow rate of conductive media up to six gallons per minute. The stainless steel, mechanically-robust design is mounted in-line providing a compact, low-profile installation for process control. The meter‘s display includes a 4-digit numeric display with eight integrated LEDs that together indicate the flow rate (gal/min or l/min), total volume (gallons or liters), and temperature (°F or °C) of all conductive media. Simple pushbutton programming quickly establishes application parameters and the flow meter can be setup to provide a switching output, analog output and pulsed output. The technology is based on magnetic inductive flow metering. The conductive medium flowing through a pipe in a magnetic field generates a voltage that is proportional to the flow velocity or volumetricflow quantity. The voltage is measured via electrodes and converted in the evaluation electronics. Typical applications include: flow and temperature monitoring through heat exchangers, monitoring cooling water on welding machines, batching applications, totalize flow of process water, and pump rundry protection. With more features than current technologies, at a price 50% less, the SM flow meter is a new benchmark for price / performance.
www.ifm.com/us
Optimass 2000
Krohne Inc.
The Optimass 2000 is a large diameter Coriolis mass flowmeter that Krohne says is ideal for accurate and repeatable bulk measurement in the oil industry.
The Optimass 2000 utilizes the effective twin straight tube design of Krohne’s Optimass 1000, and the product range has been extended with the Optimass 2000 to provide accurate measurement for the bulk fluids market. Available in three sizes, 4-, 6- and 10-inch, Optimass 2000 wetted parts are constructed of NACE compliant duplex stainless steel (ANS 31803) and the meter is available with flange ratings up to 1,500 lb, and flange sizes from 4-12 inches. One major benefit for the oil and gas industry is the low flow rate feature of the Optimass 2000. A lower rate of flow prevents the build-up of static in hydrocarbons without affecting measurement accuracy. The low flow rate capability is also a benefit for custody transfer applications. The Optimass 2000 is CRN approved and can handle process pressures to 2,200 PSIG (150 bar) with a stainless steel outer cylinder that can handle burst pressures in excess of 1,500 PSI (100 bar). Flow rates ranging from 250 lb/min (7,000 Kg/h) to 4,400 lb/min (1,2000,000 Kg/h) are easily handled by the Optimass 2000 with a measuring accuracy of 0.1%
www.krohne.com
Process Sensors
Slurrytrac
CiDra
Slurrytrac systems from CiDra are operational and analytical tools used to measure and detect sand bed formation.
Slurrytrac, a sonar-based technology that installs around a process pipe, enables step-change benefits in mining, minerals and oil sands industries. Slurrytrac is both an operational and analytical tool used to measure and detect sand bed formation and to provide new insight into slurry flow rheology. Using the velocity profile distribution of the slurry flow within the process pipe, Slurrytrac systems can detect the onset of a stationary sand bed, which can lead to plugging a slurry line causing millions of dollars in lost production and clean up, company says. The system avoids costly unplanned interventions and shutdowns due to sanding and therefore increases plant uptime and throughput.
Slurrytrac passive sonar and signal processing techniques are also being utilized by operators in plants to map out and characterize the velocity profile and other characteristics of hydrotransport slurries. The characterization, visualization and measurement information can help enable increased efficiency and recovery of the mineral content in slurries. The information as provided by the Slurrytrac system can be delivered to the DCS and/or the desktop, as well as CiDra’s information center, which can provide additional characterization, interpretation and modeling services.
www.cidra.com
Fluke Ti25 Thermal Imager
Fluke Corp.
Enables engineers to see the heat signature of electrical and mechanical equipment to scan and identify potential problems quickly from a safe distance.
Built to withstand harsh work environments, the Fluke Ti25 offers a complete, effective and easy-to-use thermal imaging solution for everyday troubleshooting and maintenance of electrical and electro-mechanical equipment. It features IR Fusion, a patent-pending technology that integrates infrared and visual (visible light) images in full screen or picture-in-picture views for enhanced problem detection and analysis. IR-Fusion helps users recognize image details and better identify problem areas by quickly scrolling through the different viewing modes. As the only thermal imagers available today in this format and price range that incorporate this capability in both the camera and in the software, Fluke thermal imaging products can be an affordable and easy solution for helping users quickly identify potential problem areas and begin analysis in the field, company says.
The Ti25 and Ti10 are designed to make the use of thermal imaging affordable and effective for day-to-day troubleshooting and maintenance tasks, featuring the ability to record and save voice comments with every image taken (Ti25 only), a three-button menu designed for intuitive operation and navigation with the push of a thumb, and on-screen emissivity correction (Ti25 only). The rugged Fluke Ti25 is tested to withstand a drop of 6.5 feet (2 meters), and is IP54 rated to withstand water and dust.
www.fluke.com
Saveris
Testo Inc.
Saveris is the wireless temperature and humidity monitoring system from Testo for indoor environment and production process monitoring that is simple, accurate, secure, and flexible.
Testo’s Saveris is a unique monitoring system offering both FCC and IC certified Wireless and Ethernet in one system. The system is designed for easy user installation and commissioning, as well as being user configurable (with “Virtual Zones”). The Saveris system can be accessorized with various external, interchangeable application specific probes. To offer more flexibility, Saveris doesn’t require constant connectivity to your PC. You can expect full data protection as both the base and probes contain EEPROM memory. Saveris communicates via displays (audible and visual), relays, email, SMS, and Internet connectivity. Saveris not only has unique offerings, but it also has merits making it award worthy, Testo says. In technological advancement, innovation lies in the sensor, making Testo a proven leader in temperature and humidity critical environment monitoring. The market impact will prove to be powerful as Saveris is an affordable wireless/wired system designed for small to midsize companies affording them an easy way to get into wireless environment monitoring. As a service to the industry, Saveris gives 24/7 monitoring of critical environments and processes. Overall, the Saveris system delivers confidence in temperature and relative humidity monitoring, therefore allowing you to be two places at once through the various communication possibilities.
www.testo.us
Control Engineering magazine subscriptions are available.
