Build OS-neutral, mobile interfaces for automation, monitoring, control applications
Opto 22 groov is a new system for building simple, effective web-based interfaces to monitor and control systems and equipment using computers and mobile devices. With only a Web browser, Opto 22... » more
Unmanaged switches
Brad Direct-Link switches come in 5- and 8-port modules and are IP67 sealed and feature an Ethernet switch solution to reduce cabling and installation costs » more
Programming software reduces engineering, speeds commissioning
At the 2013 Hannover Messe, Siemens showed its Simatic Step 7 Professional V12 programming software. The engineering software aims to shorten time to market. » more
Managed Gigabit Ethernet switches offer up to 24 GB ports, connectivity
Red Lion Modular N-Tron NT24k Managed Gigabit Ethernet Switch Series for industrial networks can have up to 24 Gigabit ports, many connectivity options, web browser management, and advanced ring... » more
Mounted ball bearings
Emerson's Sealmaster introduces material handling mounted ball bearings. » more
Warehousing solution
ITW Warehouse Automation introduced its StorFast cart-based, ultra-high-density AS/RS solution. » more
Endress+Hauser Process Training University
Process Training University from Endress+Hauser increased enrollment more than 50% in 2012, and a greater increase is expected for 2013. Companies are sending new hires as well as experienced... » more
CNC offers predictive, preventive maintenance
Fanuc 30i/31i/32i-Model B CNC offers CNC predictive and preventive maintenance tools for motors and fans. » more
Energy management is at the forefront for new Schneider Electric technology
PlantStruxure Process Expert System (PES) from Schneider Electric treats energy as a consumable, not a cost. » more
Autonomous indoor vehicle requires no facility modifications
Adept Lynx Autonomous Indoor Vehicle (AIV) is a new category of material handling automation, requiring no facility changes, saving up to 15% in deployment, the company said at the Automate and... » more
Two robots are better than one for nimble welding applications
ABB Robotics combined its IRB 660 and IRB 140 robots, creating an IRB 800 robot with 10 axes of movement for robotic welding and other highly nimble applications. » more
Dual hazardous location vortex
The HaxLoc Vortex AC model 7570 cools large enclosures with a 2-stage cooling process and can operate in hazardous environments. » more
Energy recovery wheel
The energy recovery wheel option by Daikin McQuay recovers 75% of energy from exhaust air steam. » more
Permanent magnet motors
NovaTorque has expanded their Electronically Commutated Permanent Magnet (ECPM) motors to include 3 hp and 5 hp models. They are designed to be more energy efficient and have high power density. » more
Environmentally friendly cables
EcoCable and EcoFlex by Alpha Wire are nonhalogenic and meet RoHS and WEEE requirements. They are designed to be lighter and smaller than traditional PVC cable and can be used in extreme temperatures. » more
Energy management bypass for VFDs
The P-Series of variable frequency drives by Cerus have an energy management bypass option for HVAC systems. » more
Build OS-neutral, mobile interfaces for automation, monitoring, control applicationsOpto 22 groov is a new system for building simple, effective web-based interfaces to monitor and control systems and equipment using computers and mobile devices. With only a Web browser, Opto 22... » more
Unmanaged switchesBrad Direct-Link switches come in 5- and 8-port modules and are IP67 sealed and feature an Ethernet switch solution to reduce cabling and installation costs » more
Programming software reduces engineering, speeds commissioningAt the 2013 Hannover Messe, Siemens showed its Simatic Step 7 Professional V12 programming software. The engineering software aims to shorten time to market. » more
Managed Gigabit Ethernet switches offer up to 24 GB ports, connectivityRed Lion Modular N-Tron NT24k Managed Gigabit Ethernet Switch Series for industrial networks can have up to 24 Gigabit ports, many connectivity options, web browser management, and advanced ring... » more
Mounted ball bearingsEmerson's Sealmaster introduces material handling mounted ball bearings. » more
Warehousing solutionITW Warehouse Automation introduced its StorFast cart-based, ultra-high-density AS/RS solution. » more
Software for multidisciplinary engineering
CD-adapco Star-CCM+ v8.02 is described as an easier-to-use release of integrated software for multidisciplinary engineering problems, including more productivity tools for simulation and automation... » more
Endress+Hauser Process Training UniversityProcess Training University from Endress+Hauser increased enrollment more than 50% in 2012, and a greater increase is expected for 2013. Companies are sending new hires as well as experienced... » more
CNC offers predictive, preventive maintenanceFanuc 30i/31i/32i-Model B CNC offers CNC predictive and preventive maintenance tools for motors and fans. » more
Energy management is at the forefront for new Schneider Electric technologyPlantStruxure Process Expert System (PES) from Schneider Electric treats energy as a consumable, not a cost. » more
Steel lathe chuck shields
Lathe chuck shields provide a safeguard between individuals and point-of-operation or rotating hazards, and protect individuals from flying chips, sparks, coolant, lubricant, and other particles. » more
Thermocouple sensors
The SA2 series of thermocouple sensors are available in two different mounting styles for flat or curved surfaces. » more
Autonomous indoor vehicle requires no facility modificationsAdept Lynx Autonomous Indoor Vehicle (AIV) is a new category of material handling automation, requiring no facility changes, saving up to 15% in deployment, the company said at the Automate and... » more
Two robots are better than one for nimble welding applicationsABB Robotics combined its IRB 660 and IRB 140 robots, creating an IRB 800 robot with 10 axes of movement for robotic welding and other highly nimble applications. » more
Dual hazardous location vortexThe HaxLoc Vortex AC model 7570 cools large enclosures with a 2-stage cooling process and can operate in hazardous environments. » more
Energy recovery wheelThe energy recovery wheel option by Daikin McQuay recovers 75% of energy from exhaust air steam. » more
Permanent magnet motorsNovaTorque has expanded their Electronically Commutated Permanent Magnet (ECPM) motors to include 3 hp and 5 hp models. They are designed to be more energy efficient and have high power density. » more
Energy management bypass for VFDsThe P-Series of variable frequency drives by Cerus have an energy management bypass option for HVAC systems. » more
